All hot and bothered
On my ride yesterday, ambient temps were in the 90's. My route took me through the town of Shelton. Through town with heavy traffic at the major intersections and two or three stoplight cycles at all the major crossings . The temp gauge started climbing into the danger zone. Finally got through and back to cruising speed. Temp gauge settled down and I was running fine.
Then, all of a sudden, the bike started to bog and die. My fuel gauge had gone from a half tank in town to the reserve mark. Pulled over to the side of the rode and couldn't get the bike started. Popped the gas cap. Now there was too much traffic to hear if there was a whoosh. Anyway, after a cigarette and a duck behind the nearest tree. The bike started and I had no other trouble.
Was this some sort of heat related vacuum lock that starved the bike?
I'm running on a gravity feed these days
I don't know enough about Hurricanes, are they vacuum assisted petcocks, or do they have a low pressure fuel pump? Is there a reason you're running gravity feed?
If you had vapor lock or a some other block in the vent, with gravity feed, that'll starve the carbs, which would cause the bogging and dying.
My fan runs. I'll check the coolant level again. Bike has never liked city driving with the temps over 70 degrees.
Running gravity because the fuel pump failed on the road last year and I had to do a roadside exorcism
My tank bag has a neoprene bottom I wonder if that contributed to vent blockage
Did you hear anything when you popped the cap? You would hear a big sucking sound of air if you had a vapor lock that stalled your bike.
I don't understand that unless gas was everywhere. Even if it flooded the engine, I doubt it would start up again with that much flooding.
Now that's interesting. I may have the same problem.....interesting.
Maybe drill holes in the bottom of the tank bag.LOL
