Aftermarket Exhaust
on
From twin stock cans to a single full flow open can & one side plugged.
You should shim the carb needles + 1 shim on each carb - an easy 10min task.
It gets rid of any hesitation and "lean out" and makes for a smooth throttle and power
all the way up the rpm scale.
Going back to two full flow cans - required rejetting the carbs - extra shims still
stay in.............. again for smooth power curve all the way to red line
You can just run without doing any carb mods - but you won't get the full grunt
from the motor - mpg however will be good
