After seafoam - broke the Choke 1995
After winter cleaning:
I put seafoam in the gas tank and I also used the seafoam aerosol cleaner, by fishing my hand into the air box spraying each carb individually.
After that, I had major starting / running issues (wouldn't rev over 5-6k rpms). Figured I over-did the seafoam in the gas; so I siphoned out a few gallons of the old stuff and filled it up with some new fuel. That fixed the running issues; however I am still plagued with cold starting.
The choke doesn't affect RPMs when warm, and it obviously isn't doing anything for cold starting. I have to spray brake cleaner for about 15 seconds until it gets some heat and starts idling on its own. Again, the choke lever does nothing. I had the right side cover off and could see that the choke cable is indeed connected and was moving the right-side carbs choke plunger in and out. I burned about 2 gallons to see if that would help, no issues running or warm starting; but the choke is still not working.
Am I screwed? As in I need to remove the carbs?
NEW UPDATE - SOLVED:
The gents below were right! A carb or two had a super sticky choke and would only allow it to move 30%...tricking me into thinking that wasn't it (by looking at the side, i saw it move so figured it was okay, however it is a spring loaded system so the choke cable worked perfect and was pulling the cable 100%). Based on the responses the advice was clear, lift the tank and inspect it further. After encouraging the choke linkage with my finger, it freed up. I carb cleaned and wd40 the plungers. Works great, I don't need to carry around a bottle of ether anymore :P
hurricanematt
12-02-2010 03:34 PM
