advise on jumping gear
Hey guys.. I started noticing she's starting to jump out of gear a alot more lately..specially from 2nd to 3rd and jumping out from 3rd..
Is this normally trouble with the gear selector or symptoms of something more serious with gear box..any tips on how to conclude which?
if its the gear selector I'll have a crack at fixing it somehow..not sure if honda still make these parts.
any thoughts helpful..thanks
Is she actually disengaging after being in the gear you select or is it not wanting to change, if it is just being hard to get into the next gear it could be the heavier oil you are using. Also is the oil you have changed to suitable for wet clutches because I have heard of people having problems with clutch and gearbox after running standard car oil that is not designed with wet clutches in mind.
+1, if you aren't running 10w40 bike oil atm try that first as it's the easiest and cheapest thing to go with. It wouldn't be the cause, but might not help things.
I've never heard anything about this being an issue witht these bikes. Honda gearboxes are bloody good.
Assuming it's jumping out of gear, rather than not engaging properly in the first place, my $ would be on bent / worn selector forks. I think Honda can supply any parts for these bikes.
If it's just not engaging properly, try shifting the lever position so you put more force on it with your toes. I know this sounds daft but i have heard of this causing gear selection problems in the past.
Keep us posted!
Keep us posted!
cool guys thanks.. well it all makes sense all combined ..i did go up in oil 20/50 then this issue started being more prominent..and yeah maybe i'm not kicking it the guts hard enough! lol.hmm..come to think of it its only jumping when going up to 3rd but not to3rd from 4th.maybe i should let her warm up longer before riding too..do you guys always warm up first.?
is it bad to ride these bikes conservative..i.e cruise around 3.5 on the taco in 5/4 th humming along or do they fancy the higher revs noisy riding style..one last question..are these bikes capable of lifting up? how do i lift her? gently off course. #$lol
on
Hard to lift and not a good idea given how heavy they are , if ya want to go lifting it
big rear sprocket (mid 50's teeth) and longer chain.
On the 2-3 partial shift problem ........ my 93 is the very same with new heavy oil in it
wait a few weeks when the oil thins out .....it'll be less .......and ya ride harder
As for cruising at 3.5K on the taco, I'm sure it won't do any harm, though I'd avoid dropping too much lower in high gears.
Personally speaking my happy place seems to be 4-5K in any gear, at that engine speed you've got the grunt to overtake most things and if you drop a cog you'll really fly!
Bonjour
Oils for our CBR 1000 f are generally of Motul 15W50 or YACCO.
The level measurement is done without targeting the cap (set at MAX).
Let lee heat engine three minutes. The firft is a little slap is normal, if the speed goes wrong there's no flexibility.
byes
Les huiles pour nos CBR 1000 f sont en général de la 15w50 motul ou yacco.
La mesure du niveau se fait sans viser le bouchon ( mettre au MAXI).
Laisser chauffer lee moteur trois minutes. La premiére tape un peu se qui est normal, sinon les vitesses monte pas bien y a pas de souplesse.
byes
