88 CBR1000f Engine swap
Old 01-09-2011, 08:04 PM
Tony b's Avatar
Default 88 CBR1000f Engine swap
Hello all im a new user here. I bought a 1988 Cbr1000f a few days ago. I noticed that the motor had some noise. I was thinking it was the cam chain tensioner. After removing the valve cover i found the the left side of the intake cam cap was burnt looking. I removed the cap to find that at some point it ran without oil. So not knowing the condition of the rest of the motor would i do best to find a used one and change it out? If so what all years will fit that frame?
Thank you
Attached Thumbnails 88 CBR1000f Engine swap-2011-01-09_18-14-42_596.jpg   88 CBR1000f Engine swap-2011-01-09_18-14-59_773.jpg   88 CBR1000f Engine swap-2011-01-09_13-29-26_934.jpg
Old 01-10-2011, 04:59 AM
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Ohh, there's some nasty **** going on there.
My low mileage 87 engine would fit that, but I'm using it just at the moment. If I ever get over it tho' you'll be the first one I call.
Don't hold your breath waiting though, it may be a wee while.
Old 01-10-2011, 02:36 PM
pmcg's Avatar
The engines are all basically the same. I am putting a 95 in my 87. Just a few differences with carb insulaters and you can swap them out. I have spare cams and caps if you decide to go the other way.
Old 08-03-2019, 03:06 PM
Keving007's Avatar
The 90s n up have different coolant line. I have an 88 too and need new motor. Look where coolant line comes out from upper right side ofcrankcaseof rank case
Old 08-04-2019, 01:39 AM
bonester's Avatar
I wonder if the o ring to that cam cap leaked????
Old 08-04-2019, 09:59 AM
TimBucTwo's Avatar
You are responding to an old thread.
If you have an 88 you need the MK1 type engine or switch out the pules generator as they are different and it won't work.
Cpowpow
09-16-2019 10:11 AM
TheRoachKing
04-16-2013 04:38 PM
NovaDog
03-28-2012 12:56 PM
bwiltrout
07-08-2009 02:51 PM
meatpopsicle
12-03-2006 06:59 PM
Quick Reply: 88 CBR1000f Engine swap
