87 alternator damper question
Old 06-20-2013, 07:08 AM
rookiekc's Avatar
Default 87 alternator damper question
Hello everyone,
I've got the typical starter whine and after looking at Stu's excellent article on the same topic, I took the damper out only to find out that it's not the same (his was 90).
My question is, can the 87 alternator damper be taken apart to be rebuilt(and how) and should the inner shaft spin? I've tried finger spinning it and nothing. I've also tried placing it on the alternator shaft and spinning and no luck.
I emailed Owen regarding his install of MK2 damper and very glad to hear that he was able to do it.
Thanks in advance.
Old 06-20-2013, 07:37 AM
Sebastionbear1's Avatar
Originally Posted by rookiekc
Hello everyone,
Thanks in advance.
It acts like a very tight friction damper. It has a number of plates and friction material inside that act like a clutch plate that is released. Any movement that you can detect with your fingers would not be good ............at all!
It can be dismantled and cleaned and even made a little stiffer if needed by adding a washer.
If it is like the 91 damper it has a circlip at one end which can be removed allowing the plates to be pulled out. If you do this be very careful to note not only the order but the orientation of the discs. Some are cupped.
Cheers, SB
Cheers, SB
Old 06-20-2013, 07:45 AM
rookiekc's Avatar
Thank you SB. That sounds like my damper is ok which then leads me to think that my issue is with starter clutch.
Is there any way to test the starter clutch?
Thanks again.
BIKERTUCKER
04-19-2019 06:14 AM
thedrewski86
02-12-2013 08:06 AM
Sebastionbear1
06-07-2012 09:24 PM
Aussie Johnno
CBR1000F Wanted / Swap
05-19-2012 06:15 PM
oggy
04-25-2008 11:34 AM
Quick Reply: 87 alternator damper question
