1991 CBR 1000F Sticky RPMS
Old 10-27-2014, 08:35 PM
CDrain's Avatar
New Member
Default 1991 CBR 1000F Sticky RPMS
Hello.
I've seen similar threads on RPMs fluctuating with the clutch being pressed, but I feel this is a unique issue.
My CBR does this odd thing, it won't drop below 4-5,000 rpms occasionally on decel, usually when its warm. When the engine is warm/choke off, It idles at 1k, right where she should be. The carbs were recently cleaned.
Engine was recently swapped (It was cracked when put away back in 99). When I took it out this year (first time out in 15 years), a fresher engine was put in. I don't know if it's a carb issue or the cable is sticking. Any input appreciated.
Old 10-28-2014, 03:28 PM
cbroar's Avatar
Could be sticky throttle cables or an air leak around the carbs/inlet or air screws set incorrectly.
Old 10-28-2014, 03:32 PM
Mattson's Avatar
Also betting on sticky cables or a vacuum leak somewhere in the hoses. Might be a good idea to go through all of them carefully.
Old 11-01-2014, 05:42 AM
Shadow's Avatar
Sticking cable - either throttle or choke. Check for broken strands, sometimes inside the plastic casing. Use a cable luber and you should be good to go........
BIGBAY90
01-30-2009 08:15 PM
SC240
05-10-2007 07:32 PM
Quick Reply: 1991 CBR 1000F Sticky RPMS
