Which VFR Bars ???
No. All the same height.
I know this from having been given a pair of 38mm VFR bars (as Sprock says, from an older model). I checked the lift and it's identical. 41mm dia is all you need to make them fit. You will also need to elongate the holes in the bottom of the bars to make the switches fit in the right position. The end weights will also need a bit of out of the box thinking as the internal bar weights from the stock CBR bars won't fit the VRF bars.
VFR bars after 88 should fit ok. The VFR750G/H had smaller dia forks but the J (88) onwards had the same as the CBR.
Ive just fitted some to mine off a 89 VFR750
The VFR bars have weights and like has been said the holes for the switchgear need to be slightly modified ( I ground the pegs off in the switchgear )
