Thermostat
Thermostat
Problem: Bike overheating in traffic.
Upon checking the thermostat, it was opening at 195°F (90.55°C) and should opening at 180°F (82.22°C).
I found an alternative thermostat because the Honda one is around $36 to $52 USD plus shipping and taxes whereas the replacement is $5.99 plus tax for a total of $6.47USD and is found local at any auto parts store.
What I found were, Gates #33488 but I couldn't find it local around here so I went with Stant #13868. They're like the ones used in a 1983 Honda Accord.
I removed the brass dohicky in the new Slant one because the old one had just the hole.
The fan kicks on on off like it should now rather than keep running as the bike keeps heating up.
On MK2 and MK3, remove the allen head bolt from the right upper radiator cover. Use an 8mm socket with small extension to remove the two bolts in the thermostat housing. Replace the thermostat and bolts. Takes 5 minutes.
Be sure to install it with the hole on top.
EDIT:Here they are side by side after testing both. I pulled both thermostats out of the pot at 195°F when the old one finally decided to opened. You can see the difference in the coolant passageways. The new one on the right will let more coolant flow at a lesser temp.
I went with the 180°F to stop the over heating in traffic and it did help. The bike runs better over all with this thermostat.
Let me know and thanks!
Warner
Warner
Thermostat:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Oil:
Oil Filters:
Warner
