Alternative Parts What fits where, what else will fit, resources + bike manuals
Making a custom top triple
Old 07-17-2016, 08:07 AM
cb750tr's Avatar
Default Making a custom top triple
Hello all you great people of CBRforum!
So, I am currently building a custom CB750, where I am using a CBR1000F front end. Yesterday I managed to get some work done, and got the stock fork off and test fitted the new CBR1000F. It looks great, and the geometry is close enough so that I will be able to get good rideability.
However, I need to make a custom top triple for it. As I didn't get one when I purchased the forks, I was wondering if anyone here got the measurements (mainly the three c.t.c). If there's any interest I can upload the finished CAD so anyone can modify it to fit their projects.
Thanks in advance!
Old 07-17-2016, 09:11 PM
Conrice's Avatar
I'd buy a cheap one off eBay, use it for measurements and sell it (some shops on eBay even have a return policy!)
Throw up some pics of that project though!
(And good luck with it BTW)
Old 07-18-2016, 06:40 AM
Gazz's Avatar
Hi mate
Cut a ply board roughly the size of the whole thing, use a hole saw to cut the require holes then fab up on in car bog or plaster of Paris, when set gently shape to dummy to exactly what you want then drop it into an engineering shop and get them to mill it out of a piece of billet aluminium
.hope that puts a rough idea in place
Old 07-18-2016, 12:36 PM
cb750tr's Avatar
Thanks for the reply!
The idea already struck me, but the problem is that I do not have anything fancier than digital calipers or micrometers, which doesn't give me the precision that I would like. Even a few millimeters off will bend the legs ever so slightly, which will increase the forces exponentially. If it makes much of a difference or not I do not know, but I would like to see if I can get the precise measurements before I try to measure it myself.
Regarding pictures, I have a build thread here;
http://forums.sohc4.net/index.php/topic,157587.25.html
I am just getting to the interesting bit (rebuilding) so it will hopefully get more interesting as the build progresses.
Originally Posted by Gazz
Hi mate
Thanks for the reply by you as well!
I could do it like this, but there are two apparent problems that I face. First of all I only have one point of fixture of the legs, which means that I most likely do not have them precisely straight. I could mimick the lower triple (which I have) but as I do not know if the top is identical to the lower triple that isn't a perfect idea either.
Besides, I want to design my own triple and just get it CAD milled so I can't really drop a mold off. But it's a good idea other than that! Thank you
Old 07-19-2016, 05:15 AM
Gazz's Avatar
Just a thought, if you done the mound scenario it could then actually be scanned directly into a cad program by the engineering shop then pretty it up or personalise it however you want prior to milling.
We are doing ground up builds on two old cb750/4's and I'm going to use cbr1000f front ends
Anyway best of luck with it
Old 07-19-2016, 03:54 PM
cb750tr's Avatar
I made a quick drawing of how I kind of want it to look, design isn't completely finalized and it's rough around the edges (and obviously the measurements are just out of my ***, so the relations aren't 100%).
But at least it gives me somewhat of an idea of what I want to do. I didn't bother with putting any holes in, but I was planning of making the tach mount point in the square around the steering stem.
Old 07-20-2016, 05:39 AM
Gazz's Avatar
That looks really good. I'm a lover of the kiss method mate, even a couple of holes with threads tapped into the leading elevation of it them manufacture your gauge support to be attached via those two threaded holes
Like it.
I actually bought another cbr1000f today, a 95 model and toying with ideas for it
Old 07-20-2016, 03:30 PM
cb750tr's Avatar
Like it.
Thank you!
I need to get my front assembled and the gauge in hand before I make any decisions on how it will be mounted. But I've got really high hopes for this build
Old 07-20-2016, 05:07 PM
Gazz's Avatar
It's great to see and watch these builds take shape. The ones we are doing we are building in what I call soft form and it's really just assembling the bikes to a point we like what they look like, which sees a lot of changes upon changes then we will again pull the bikes apart and at that stage take off any unwanted previous mounting points etc then paint frames etc once we are happy with the build.
Saves getting to the end of it and thinking oh we should of done this or that.
We have a spare front end off a cbr1000f and are using that on one of the 750's while the other I think we will stay with a genuine 750 set of forks but lowered a bit
