900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
GP Shift Mod 98 CBR 900RR
Old 04-22-2009, 10:47 AM
Silverman925's Avatar
Default GP Shift Mod 98 CBR 900RR
Thanks in advance for any help with this...
I have started attending track days and very quickly realize the importance of GP Shift capabilities.
I have head that a CBR 900 would reverse shift with a simple VFR shift lever installed. But I cannot find part numbers for this lever, and I cannot find info on which year VFR will fit a 98 CBR 900RR...or if there are more parts i would need.
New rear sets are $300+...and a VFR Shift Lever is $30.
Has anyone done this mod? Can anyone point me in the right direction? I definately want GP Shifting before Road Atlanta in June.
Old 04-22-2009, 06:06 PM
speedextreme's Avatar
Simple, you can do it one of two ways. One way is without purchase of anything. Take the 10mm head bolt out of the linkage that is on the shift shaft. Take that "arm" linkage off the shift shaft. Rotate that arm 180 degrees and put back on. NOW, if your shift linkage hits the frame take and bend that linkage ever so slightly to clear the frame. You are done.
OR
You purchase a 929 shift linkage arm. The one that goes on the shift shaft. It is bent a little different than the 900's. It works!!!
Trust me I have done both ways!!! Works like a champ.
Old 04-28-2009, 01:56 PM
Well, I got the 98 VFR shift lever and it fits perfectly. It was a three minute mod! No bending rods, no complications at all! Highly recomend it. Lever was $30, and I can even put the old settup back on (because it isn't bent) anytime I want to. Also eliminated all the slop in the linkage. feels great!
Great idea!
Old 04-29-2009, 10:22 AM
axelthrasher's Avatar
I would love to see some pictures of this on some CBRs. After readint this I am considering doing this as well. 1 up and 5 down sounds like it might be worth a try for me.
Old 05-06-2009, 11:58 AM
woodytick's Avatar
i have mine flipped around on my 900 & also on my vtr1000f. i love it this way. it is so much easier i think when riding.
Old 12-01-2010, 08:17 AM
LJ Harp's Avatar
Official CBRF Decal Man
Im going to.bring.up.a real.old.thread but does anyone have pictures like asked begot I want to try this tonight
Old 08-05-2011, 05:01 PM
woodytick's Avatar
dude take it off with a 10mm wrench just like they said. flip it over 180* and you have it. it takes less than 3 minutes to do.
Old 04-03-2013, 02:55 AM
brilliant. just did this. used the "bend" method. then i reverted it back to stock just to see how much i messed it up. not bad at all.
Old 11-03-2014, 12:08 AM
ambeos5's Avatar
ROTM, Oct 2014
trolling threw the threads i saw this one, what is the point of this mod? to make the shifting smoother? if so i would love to do this to mine.
Old 11-05-2014, 08:28 PM
coalminer frank's Avatar
The point of this mod is to allow upshifts while leaned over through a left hand turn. So your toes will not be squeeze between the tarmac and shifter. You should never have to down shift in a left hand turn (or right also) but you might need to upshift. Technically, you should get all your down shifting done while straight up before the turn. Plus its easier while in a speed tuck to push down to upshift.
Quick Reply: GP Shift Mod 98 CBR 900RR
