900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
900rr to f3 front wheel swap
Old 09-26-2010, 09:00 PM
otello's Avatar
Default 900rr to f3 front wheel swap
Ok guys a quick question.....
I know that with some washers we can make an f3 rim fit into our 900rr, but can the 900rr rim fit the f3? My brother has an f3, and h is letting me have the front rim, but my rim has to fit the f3 isthat possible? any info is greatly appreciated!
Old 01-08-2011, 09:26 PM
Hondas Rule's Avatar
The F3 wheel will fit your bike using your stock spacers 93-97 900RR, 98-99 is wider and has different brake rotors. You wheel should bolt right up on the F3 as long as your RR isn't the early 93-94 with the mechanical speedo drive
Old 02-07-2011, 10:24 AM
crazy_rider's Avatar
sup.what year f3 front rim would fit the 900rr. also would the handleing get better or worse
Old 02-07-2011, 12:50 PM
LJ Harp's Avatar
Official CBRF Decal Man
Im also interested in this I have a 96 blade and was contemplating a larger front rim
Old 03-01-2011, 12:09 AM
The F3 wheel is a direct swap from 95-97 RR's, The 93-94 needs a little work because of the mechanical speedo drive and the 98-99 RR has a wider triple tree and larger brake rotors. If I can answer any questions for you guys you can email me at dartman672000@yahoo.com, I don't check here very often since I sold my RR and ride an R1 now
Jim
kmixxed
07-21-2011 01:25 PM
ssweetbro
05-13-2011 05:39 PM
ssweetbro
04-27-2011 11:38 PM
redforlife
08-17-2008 04:06 PM
Quick Reply: 900rr to f3 front wheel swap
