900 & + Modifications This section is specifically for questions and advice pertaining to mods of the older models, 900 and up.
39mm Keihin FCR carbs on 95' 900 RR
Old 07-27-2008, 12:58 PM
ss6r's Avatar
Default 39mm Keihin FCR carbs on 95' 900 RR
I am in need of jetting information for 39mm keihin FCR flatslide carburetors if any one can help it would be greatly appreciated. I have a 95' CBR900RR with a MVR 4 into 1 full exhaust and a stock motor. I asked SUDCO and they will not sell me or give me any jetting info. These carbs originally came off of a Yamaha and the jetting was way off for the 900rr. Changes have been made to them so far but still can't get them right, when you roll on the throttle it picks up good and goes, but when you hammer the throttle the bike boggs and hesitates before smoothing out and accelerating hard. Thanks
Old 10-18-2008, 08:19 PM
Default RE: 39mm Keihin FCR carbs on 95' 900 RR
My setup is pretty similiar to yours. I run a #120 jet but it could use a little more. Also having them synchronized would help alot
Old 01-11-2009, 04:55 PM
I am building a pulling tractor with a 95 900rr engine. I was wondering what air filters and what are you getting these carbs off of?
Old 06-19-2009, 09:01 AM
bigpipe's Avatar
Default 39mm Keihin FCR carbs on 95 900 RR
I have a quick question about boring a 41mm FCR. Do you bore the 41mm carbs? and how large can you bore it to? I am looking at maybe boring it out when I bore my bike to a 500cc later this summer.Thanks, Rob Deimn guys! Black eyed peas - Boom boom pow has blowed my brain ))) try it and write me PM your mind)
Old 07-03-2009, 05:18 PM
jason600's Avatar
with those carbs u can never just crack the throttle it will always bog
Old 09-09-2009, 07:03 PM
dylanr's Avatar
Default fcr carbs
i have a 600f3 with the fcr carbs and i have the same problem. if i roll on the throttle it runs great but if i crack the throttle open it bogs.
jackojeff
07-11-2013 11:10 AM
ryano900rr
11-18-2009 08:40 PM
ducatijay
01-09-2008 06:42 PM
Quick Reply: 39mm Keihin FCR carbs on 95' 900 RR
