600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
want a bigger rear tire on a 90 f1, what kind of swing arm can I use
Old 12-19-2006, 06:42 AM
mitchedwards81's Avatar
Default want a bigger rear tire on a 90 f1, what kind of swing arm can I use
help me
Old 12-19-2006, 09:54 PM
Default RE: want a bigger rear tire on a 90 f1, what kind of swing arm can I use
I'm not positive, but I think an F2 swingarm will work without too much, if any modification. You can get a 180 tire in there, not sure about what size wheel will fit. But the 180 tire on the stock F2 wheel looks kinda funky 'cuz the sidewall has to come in so much to fit in the bead.
Old 02-06-2007, 07:22 PM
ORIGINAL: zerochickenstrips
...not to mention it will completely destroy the handling of the bike.
If you're gonna use an F2 swingarm/rim, stick with the stock tire fitment for the rim. The F2/F3 ran a 160/60/17 rear tire stock. Going to a 180/55/17 is going to change the shape of the tire significantly, and will likely make the bike turn in a less stable manner. Do a little hunting, and you will find articles from reputable sources saying the same thing.
I made this same mistake years ago with my first sportbike, a 1990 FZR600 (I wanted a more substantial looking rear tire for appearance reasons). It made the bike dangerous at extreme lean angles.
Old 06-18-2007, 12:05 AM
cbrpilot's Avatar
Mitch, First, chris_mag's right about the jump to 180's. FYI, the F3's rear wheels were 1/2 inch wider than the F2's. I'm not sure if Honda widened the f3 swingarm to accomodate the F3 rear wheel, but it would've made sense. I'd compare swingarm widths between the F2 and F3's and go with the wider s-arm, and no larger than a 170 tire. Most experts recommend not exceeding 1 size over the manufacturers assigned tire. Otherwise add a rim from a liter bike to use the 180 tire. Should be able to pick up a F3 s-arm on EBAY for 15 bucks. cbrpilot
Old 06-19-2007, 12:14 AM
Interested in this myself, would the chain clear that wide of a rear tire? Does the front sprocket need shimmed to do this? Is so how and with what?
Brian
Old 04-18-2014, 01:25 PM
No1spank's Avatar
A 150 fits the stock F1 rim, I used a Michelin Pilot sport on mine, the handling was no worst but it was well used and not a great handling bike anyway.
F2 & F3 swingarm are the same, F2 rim takes a 160, F3 is good with some 180's but all 170's.
Kat-Tee
F2 Tech
07-22-2010 10:07 PM
tutman6
03-04-2010 12:40 PM
paddysasausage
10-27-2007 08:14 PM
gmejr
03-03-2007 10:48 PM
greymustang
01-06-2007 06:24 PM
Quick Reply: want a bigger rear tire on a 90 f1, what kind of swing arm can I use
