600 Modifications This section is specifically for questions and advice pertaining to mods of the older 600 models.
Hydraulic Clutch conversion for F4
Old 06-02-2012, 03:31 PM
Edward Tristram's Avatar
Default Hydraulic Clutch conversion for F4
Hi guys, any potential issues you can see with installing one of these?
I mean it's probably a bit dinky considering the price but if the Chinese can produce something that works well enough it's well worth the $70. I saw a guide online that tells you how to install one on a dirtbike. The hardest part seems to be drilling a hole in the bracket that the slave unit fits into so that you can bolt it to your clutch cover. I also heard about some compatibility issues with different pressure ratios and stuff.
I've personally never even bled my brakes or anything like that yet so I'll probably swap out my front brake lines for some stainless ones and after installing them I'll tackle this job, but in the meantime does anyone have any thoughts? If anyone knows the best length to get that would be a helpful tidbit...
Old 06-02-2012, 06:21 PM
MadHattr059's Avatar
The slave actually should fit in place just like the cable-end does.
It's a fairly bolt-up replacement, IF the cable is the correct length.
The real concern, is fit/fitment and he's a LOOONG way away for tech support.
The other issue is he's only made 11 sells. You might want to wait till he gets
a better sells-record, before dipping into the waters.
Hope this helps, Ern
Old 06-03-2012, 02:29 PM
Yeah. I might get restless and impatient and just go for it and eat the $70 if it doesn't work out. I'll keep you guys posted
Old 06-03-2012, 07:43 PM
If you do get them let us know! I got spoiled on my 84CB700SC, so I've considered
this same thing. The closest I've found was the Magura stuff. But they're a german
brand and the english site is rather obscure and difficult to determine the right kit.
So it's been a back-burner project for me.
Ern
Old 06-04-2012, 11:30 AM
coalminer frank's Avatar
I liked the hydralic clutch. Had an 84 V65 Sabre in 1985, 17 year old kid with one of the fastest bikes made at the time. It threw me down the road a couple times.lol
Old 06-21-2012, 06:33 PM
boredandstroked's Avatar
Ahhh hydraulic clutches, providing zero lever feedback for many years.... Most manufacturers ditched hydro clutches and went back to cable for a reason.
subyman1440
12-24-2012 06:51 AM
patches_mcmatt
04-07-2011 06:31 PM
fbpsb82
01-30-2010 02:23 PM
recklessrider
08-30-2008 05:04 PM
malbojah
11-08-2006 03:55 PM
Quick Reply: Hydraulic Clutch conversion for F4
