Eliminate speedohealer
Speedodrd?
Where can i get one of these from? Ebay?
F2 calibration
Correction, just found out i have an F2 motor on an F3 frame, anyway I still did the F4i conversion and i got the sprocket cover and speed sensor from an 97 Cbr 900rr, it's now giving a reading but waaay off. My question is, what bike should i get the calibrator for? The 900rr, F4i, or the F2? Anybody know the model number i would need for the Speedodrd and the model number for the speedohealer? Just want to make sure
I can only vouch for the Speedo Healer and I can honestly say I recommend it. It is so easy to install, all you have to do is unplug the speed sensor on the right side of the frame and plug the Y harness is in and run your cables and mount the box. I calibrated it to my gps and it is dead accurate at 130 kh/h. Their website will tell you what harness you need. It also has a calculator on there to help you figure out the % you need to adjust for. Hope that helps.
cbrboyze
How-To: Mechanical
03-05-2009 08:47 AM
