Acewell on my f2
yes i have the useless manual :P
bought this one: Acewell - Acewell Accessories and Sensors - Speed Sensors - Cable Drive - ACE-S8 Screw in square drive adaptor | Digi dash | Digital Speedomter | Motorcycle Computer
this is what the acwell guy said to me:
You should connect to a wire that only goes to one coil. Not the one that splits
You have 2 options.
1, use an ACE-S / ACE-G or ACE-S3 sensor and replace one of your disk bolts with a magnetic bolt.
2, use an ACE-S8 sensor to replace the speedo cable, but you would need to open up the ACE-3803, unsolder a wire, and resolder into a different location on the PCB - easy to do as long as you have a soldering iron.
The soldering bit is easy...
unsolder the green wire from the point on the PCB marked "speed" and resolder at the point marked "hall"
You have 2 options.
u should contact acewell about it and maybe get a replacement.
i am going through the same problem with a similar gauge i got from Danmoto, an ebay dealer from china. they sell a knock off of the acewell and others. my guage seems to be working fine on the speedo , but the tack is off. i am sending mine back for a refund. i found a member on another forum that has the Danmoto acewell knockoff that he is selling me for $75. i hope it works ?
