95 F3, 600rr rear swap
has anyone else tried this?
i'm knee deep in it now and hit a wall... don't have the tools to get the right side swingarm bearing out of the damn thing
putting this swingarm off an 05, with 07 suspension (single dogbone suspension linkage bolts up in the same spot
which is going here-
alrighty... a very long time later i'm back... i was just in too much of a hurry and was trying to get the bearing out the WRONG WAY ... so once i figured that out i also figured out the stock F3 swingarm pivot was WAY too small... and i discovered a nice lil trick, the F3 FRONT AXLE is the same size as the 600rr swingarm pivot ... so i may have made the hole a lil bigger to fit the bolt in... but finding bearings was STILL an issue... the part of the swingarm i narrowed needed a smaller bearing obviously, and the bearing company said i was screwed... also the shock mounts are difficult to make without a welder.......
then i ended up trading my non running f3 (carbs still not on) for an 88 FZR1k (damn rocketship) and rode that around for a few months then sold it to a fellow Wyotech student in FL and Moved back home to the Colorado Mountains, where i am an ATV/ Snowmobile mechanic
