new chain when changing rear sprocket?
Old 06-06-2014, 03:03 AM
bobobob's Avatar
Default new chain when changing rear sprocket?
I recently bought a 2005 600rr with a 47 tooth on the rear.
The acceleration is fun, but it seems to respond less smooth on the throttle.
Im thinking of switching it back to stock or somewhere in between.
Is there a way to calculate when and if i need to adjust my chain.
Thanks!
Old 06-06-2014, 06:52 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
How many miles are on the old chain? If the chain is fairly worn and you install just a new sprocket the chain will wear it down somewhat faster than if you replaced both front and rear sprockets and chain.
You can find kits that have all 3 for less than buying each component individually.
Old 06-06-2014, 02:57 PM
bobobob's Avatar
The complete chain set is fairly new.
Really wanna know if I can use the same chain lenght of the 47t for a 42 tooth for example.
I guess there's some sort of formula for that right?
Old 06-06-2014, 10:06 PM
RoadiJeff's Avatar
There might be a formula but if you're going from a 47T to a 42T you could just install everything, move the chain adjusters to their shortest positions, wrap the chain around the sprockets and see if any links need to be removed.
Do you have a chain breaker/rivet tool?
Old 06-07-2014, 01:32 AM
bobobob's Avatar
True... I just wanted to make sure it fits before I go out buying a new sprocket 😁
Now I need to figure out if I'll go stock or go halfway...
Old 06-08-2014, 07:21 AM
N8 Dawg's Avatar
If your using the same chain then it would need a few links cut off. You might be able to by another master link, but if your replacing one sprocket why not just replace both sprockets and the chain and do it right? Its really not that expensive if you already have the tools to do it.
Old 06-14-2014, 03:27 AM
bobobob's Avatar
True, but the set is still pretty new.
Picked up a 42T rear today, see how i like it....
Im trying not to cut the chain (at first) so i can try some different rears.
Old 06-14-2014, 05:40 AM
Mattson's Avatar
You can cut the chain by carefully grinding down the rivets from the link to be removed with an angle grinder, just go easy on it so you don`t fry the seals. But on bikes this powerful it`s heavily recommended to NOT use a clip style master link, I`ve succesfully riveted one chain with a small vice and a ball head hammer but it` s really up to you can you do it or let a shop take care of it for you and have peace with it and know it`s done right.
There are numerous different calculators for the sprockets in the net
https://www.rbracing-rsr.com/chainlength.html
REBEL GEARS CUSTOM MADE MOTORCYCLE SPROCKETS ANY SIZE
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
Here`s a few, took me a minute to google and link.
Old 06-16-2014, 04:47 AM
bobobob's Avatar
So took the rear wheel out, unbolted the sprocket, put the "new" one on, put the wheel back on, slid the chain on....
and...
previous owner put on a 520 kit instead of the oem 525
Mattson: thanks for the links!
j0shi3
04-13-2014 11:12 PM
f3BikeR
12-17-2008 09:56 AM
bluestanger66
07-27-2007 11:48 AM
Quick Reply: new chain when changing rear sprocket?
