HID projectors/Angel eyes/Demon eyes/audi lights (lots of pics)
based on my retrofitting project...
ok, i was going to do a write-up after i received our co-membes headlights... because i dont want to peel off my headlights again.. retrofitting took a lot patience, the longest time took me was proper aiming.. and i did not buy all the stuff from that store.. because they are way to expensive, i bought them most from china.. i will sort out stuff what to buy on which store k?
china: Guangzhou HYD Auto Parts Co., Ltd. - projector lens, hid bulb, hid ballast
1.Mini-H1 projectors
2.shrouds of your choice, theres only 3 small ones that can fit the headlight
3.shroud rings (to fit the shrouds properly-some shrouds are bolt-on)
4.H1 hid kit- i have fast bright ballasts (full brightness 3 sec.) your choice
of kelvin rating
5.leds- for demon eyes- (the red on my projector) red blue white amber etc.
your choice 9
6.ccfl- (the Halos) any color same as leds, your choice.
7.ccfl ballasts- to power the halos
TRS- The retrofit source: The Retrofit Source online: headlight upgrades for all applications
1. H7- relay harness for bike (well made) (both headlights run low beams
at same time)
2. the high beam splitters- h7- 9006/9006 (wired to high beam, controlls the
solenoid of the projectors, both high beam in command)
parts store:
1. metal sheet- g .24 (to replace the reflector to mount the projectors)
like the drawing you attached..
2. pair of snips.
3. small screws to screw the projector. to the metal shhet
4. silicone glue..
5. dremel!!!- most important
6. paint- high heat paint, to paint the solenoid and the shield inside
the projector (reflects the color of the leds better, mine is red hh paint and red leds)
- any automotive paint/primer- to paint your shrouds (your choice)
7. a switch- (optional) i bought my handlebar switch from a bike shop
thats all i can think off for now... these were my choices whe i customized everything, if you want it easy, you can also buy ready made projectors but outputs were terrible... plus its hard to customize those ready made ones.. at least you can paint the shrouds (covers the projector and where ccfls are mounted) according to your bikes paint to complete the look..
hope this helps
pics for you guys..
low beam
high beam
cut-oof view
switch for hid's
of kelvin rating
your choice 9
at same time)
parts store:
2. pair of snips.
4. silicone glue..
hope this helps
pics for you guys..
low beam
high beam
cut-oof view
switch for hid's
Onarom
How-To: Mechanical
80
02-04-2013 02:00 AM
F4iMiller
12-30-2008 02:53 AM
